e-brake light always on
Re: e-brake light always on (ACTEG)
check to make sure something isnt grounding out the switch under the ebrake handle and also check to make sure that your master and slave cynlinders are at the correct level of fluid.. if these things check out you have a bad switch or wiring problem under the dash..
Re: e-brake light always on (95CivicEX)
CRX T-Si
16
06-23-2006 11:30 PM
