How can I get even better mileage out of my already fuel effeincent car?
I am just curious what i can do to my or anyone elses car to get a little better gas mileage this whould include everything exept routine mainteniece. Anything you can think of would be great - thanks
Re: How can I get even better mileage out of my already fuel effeincent car? (jimmy o.)
make sure your tires are properly inflated. Dont get on the pedal much shift sooner. re-gear your car. put a bigger motor in a lighter car.
tire inflation would fall under routine maiteince . I am talking about stuff you can put on or take off your car for better mileage and driving fast is too addictive although I still get around 35mpg
Re: (jimmy o.)
Put your car on a diet. Less weight = less fuel to burn to get and keep it moving. Lightweight tires and wheels will likely make the biggest difference unless you are already running little steelies and pizza cuters.
H-T White Ops
Check GasSavers.org. You can keep track of your gas mileage there on a chart (which compares the stock gas mileage too). This can help to keep your driving style in check.
They'll also have more ideas in their forum.
^yes, that helps a lot
Add a rear diffuser
Seal off gaps between body panels
Add a front spoiler
Add an afc or ecu chip to run the car slightly more lean (though not too far)
This has been covered a lot lately - search for more.
Add a rear diffuser
Add a front spoiler
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
Add an afc or ecu chip to run the car slightly more lean (though not too far)</TD></TR></TABLE>
Thats scary.
Thats scary.
Isnt it? Easy way to go too far, especially if you have no clue what youre doing.
But it would definitely work and has been done.
The maps on my ecu are decreased slightly, actually...though I havent run it yet
Re: How can I get even better mileage out of my already fuel effeincent car? (randomtask77)
So...my son put 14" rims on my 92 DX. Looks like it came standard with 13". If I go back to 13" rims do you feel my mpg will incrase? I do not have widers tires just 14" instead of 13". I get 39mpg now...how much of an improvement might I see?
Thanks
Thanks
If you lower the car, it will reduce the amount of air going underneath it. this will reduce the drag and give you noticeably better fuel economy.
Skinnier tires with lower drag will also help.
Weight reduction will definitely help, especially around city with lots of stop and go. At highway speeds, air drag and tire drag are the 2 major factors.
eswaroop2
04-22-2004 11:01 AM
