Do i need to replace my cluster...
i have issues with my speedo, i have searched far and wide and so far nothing
i have done has fixed the problem...replaced all grounds/fuses/and the speed sensor
itself, twice, and the speedo is still posseed!
i will do a few different things, either not work at all, jump around from 0-100
40-100...60-80 w/e the case it varies all the time, also it will be working showing my current
speed then the needle falls just to 0 or jumps around like crazy like said before...
it does all this while driving and alot while in neutral not moving too.
PLEASE HELP GUYS!!
PLEASE HELP GUYS!!
Re: Do i need to replace my cluster...
if you've replaced everything I guess it's probably the gauge itself?
I know at least on EKs you can swap out the individual gauges easily, so if you can find just a speedo for cheap or a dx cluster w/no tach or something for cheap, it's just 4 screws in the back of the cluster to take it out, no wires, the screws make the elec. connections
that's usually something electrical, unless there's something wrong behind the gage. try swapping it, you won't even need a diy. it's pretty much common sense when taking gauges apart and putting them back together
timmytooloud
04-11-2016 01:45 PM
axtran
06-06-2006 02:23 PM
