Do i need a camber kit?
Old 06-01-2009, 04:12 PM
realxfresh's Avatar
Default Do i need a camber kit?
I have a 96 civic coupe. I dropped it on tein s techs with tokico blues. can i get an alignment and will it be good or will i need a camber kit?
Old 06-01-2009, 04:21 PM
mugen si's Avatar
Default Re: Do i need a camber kit?
just get an alignment and set the toe to 0 or within factory specs.
Old 06-01-2009, 05:20 PM
waaBAAH's Avatar
it depends...what are you trying to accomplish? answer these two questions..
1. do you care about tire wear.. rate your tire wear concerns on a 1-10 scale.
2. do you care about handling? rate your handling concern on a 1-10 scale.
now add up your scores... (P.S. you only have 10 points to work with from up there ^)
Old 06-01-2009, 05:35 PM
thumper64's Avatar
...how much of a drop?
I'm only like 1inch below stock and I'm like 1* negative camber, not an issue at all
Old 06-01-2009, 09:23 PM
Master Detailer
98civdx's Avatar
tein s techs are normally just below 2in
NO you dont need a camber kit, go in and have them align it and get it as close to stock camber as they can.
and have the toe at 0,
toe eats your tires quicker, camber will but not so much,
Old 06-01-2009, 09:34 PM
waaBAAH's Avatar
camber isnt adjustable factory ^^
Old 06-01-2009, 09:38 PM
Master Detailer
98civdx's Avatar
i know.
forgot it was a civic lol
Old 06-01-2009, 09:40 PM
batallic's Avatar
just get yur toe adjusted to factory specs, it eats tires quicker than camber
inspector01
Suspension & Brakes
13
06-27-2008 04:12 PM
TegoDC5
15
10-20-2004 10:01 AM
vbspec
10-08-2003 04:52 AM
MikeyDB7
03-13-2003 03:22 PM
KraZyCHOWMEIN
12-19-2001 07:58 PM
Quick Reply: Do i need a camber kit?
