dizzy question
dizzy question
ive searched and no one really answers this...
can a NON-VTEC dizzy work on a VTEC motor and viceverca...basically does it matter. i dont think it does since the dizzy has nothing to do with vtec timing. but correct me if im wrong
flash
flash
Re: dizzy question (flash94civicsi)
my friend had a dizzy from a SOHC ZC motor and tried to run it on his d16z6 and it ran like ****.
The correct dizzy for the motor is needed. We put on my d16z6 distributor on hid d16 and the car ran like a charm with mine on.
So it does make a difference on the way the motor will run
Re: dizzy question (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">i would like to know as well. so the motor will start, but will NOT RUN RIGHT..please confirm</TD></TR></TABLE>
Using a distributor from a ZC motor on a d16z6 will make it run like ***
even ask my buddie martin (xgenturbo) on here...we put on my distributor from my Si and it worked properly on his d16
Location: Why so you can pretend like youre interested, FL/OK
Re: dizzy question (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">doesnt a sohc zc have vtec? ive seen people on here use vtec dizzys on non vtec motors just one of the bolts doesnt line up or something like that.</TD></TR></TABLE>
Comes in different models. Vtec as well as non-vtec.
Anyway, what about the obd1 dx distributor on the obd2 ex's. That's non-vtec to vtec. From the information I've seen it hasn't listed any difference in running. Some state they have issues with timing others state they do not.
https://honda-tech.com/zerothread?id=927061
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">well, i checked hondaautomotveparts.com and checked the part #'s for a 95 dx and a 95 ex and its the same part #.</TD></TR></TABLE>
Check again. A non vtec dizzy will not work on most Vtec motors. They have a different tooth distance and length. Most people grind the tabs to make them work . Just get a Vtec dizzy or non vtec dizzy and do it right. The Vtec dizzy's EX VX and Si have a different part number than non vtec dizzy's DX CX and LX. I even went down to Honda and asked them and they were kind enough to show me the difference and why it wouldn't work. I was suprised how helpful they were and how they were willing to actually show me.
Re: dizzy question (Bond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">
Check again. A non vtec dizzy will not work on most Vtec motors. They have a different tooth distance and length. Most people grind the tabs to make them work . Just get a Vtec dizzy or non vtec dizzy and do it right. The Vtec dizzy's EX VX and Si have a different part number than non vtec dizzy's DX CX and LX. I even went down to Honda and asked them and they were kind enough to show me the difference and why it wouldn't work. I was suprised how helpful they were and how they were willing to actually show me.</TD></TR></TABLE>
thats exactly what i wanted to know.
quick ? for you, i bought a d16y8 swap with a suppose vtec dizzy, now the swap runs, but it runs shitty as hell. idles perfect but when you start to drive it, it feels very choppy and i can ONLY rev to 45 mph. i also, have a d16y7 dizzy and on the dizzy has the same type numbers. now did i get a dx dizzy or an ex dizzy.
thats exactly what i wanted to know. </TD></TR></TABLE>
I could have answered that for you the other day. I tried it when my the spare car's dx distributor took a crap. I tried to see if the ex/si would work, but the mounting locations on them prevent it. The dx looks a bit smaller than the ex as well.
well, ive heard otherwise. i think that it should work with no problems (using dx dizzy on an ex head) i mean, there's nothing in the dizzy that controls vtec. there has to be someone whose done it
flash
flash
the guts are the same i know because i have used guts out of a accord 92 motor in my b16 dizzy and the are the exact same thing, you can also use the guts out of a 92-95 civic they are also the same. The arms on the dizzy are different but the internals are the same.
Re: dizzy question (716pro)
interesting because my y8 head i bought came with a a6 distributor *which is NON-vtec* and the guy said it pulled hard as hell and was good...kinda weird
The tabs are different. Anybody that is running a non vtec dizzy on a vtec engine has modified the tabs (grind, cutting, etc.). There is no way that they will just bolt on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">The tabs are different. Anybody that is running a non vtec dizzy on a vtec engine has modified the tabs (grind, cutting, etc.). There is no way that they will just bolt on.</TD></TR></TABLE>
true...i have a 00 ex head and im going to get a 92-95 dx dizzy to see if itll work. (00 y8 in a 94 del sol)
All D series are the same other than the D16Z6 ones which have the tabs further apart. All the guts are the same and if you swap the guts from a non vtec into a Z6 housing it will run perfect. Z6 dizzy's are the only queer ones.
Re: dizzy question (delslo93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 »</TD></TR><TR><TD CLASS="quote">All D series are the same other than the D16Z6 ones which have the tabs further apart. All the guts are the same and if you swap the guts from a non vtec into a Z6 housing it will run perfect. Z6 dizzy's are the only queer ones.</TD></TR></TABLE>
From what i understand too
EDIT: My link to my y8 head with a a6 setup...pics could be found here https://honda-tech.com/zerothread?id=1257765
es.roadster
Northern California (Sales)
10-20-2011 10:01 PM
JJDd16z6
09-21-2011 01:44 PM
