diy fuel tank repair?
Got a small hole in the bottom of the fuel tank. I saw some "repair kits" available and they all seem to be some sort of epoxy based. Could I just use the 2 part epoxy I already have and plug the hole? Would JBWeld be suitable for such a task?
Mr. Badwrench
Re: diy fuel tank repair? (blaze_125)
you need that crap the dude on monster garage needed because he thought he wsa a welder and wanted to show up jesse james.
there is a fuel tank sealer. truck stops have it, cant remember what it is called. i dont think jb weld will hole gasoline.
nope that **** wont cure properly if there's any gas around and the gas might eat it after it's cured, the gas tank repair **** works but don't expect it to last forever i hit something on the road one time and punctured my tank and used that **** it held up for about 3 months or so. just make sure the area around the hole is clean and u scuff it up so the expoxy has something to grab on i was on my way home to Ontario from Alberta so i was not going to change my tank in the middle of nowhere
Re: diy fuel tank repair? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">you need that crap the dude on monster garage needed because he thought he wsa a welder and wanted to show up jesse james.</TD></TR></TABLE>
There is no way in hell I'ma take a welding rod anywhere close to that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">http://www.4secondsflat.com/Fuel_Tank_Sealer.html</TD></TR></TABLE>
Thanks, but they don't ship to Canada
I'm guessing using my already owned epoxy is out of the question. I'll see if I can source a "repair kit" around here
When I got my S14 240SX it had a small crack in the gas tank and I put some JBWeld on it...it lasted for a couple of months, but the crack was on the top of the tank, so I didn't really get it plugged off too good.
It may work, just give it PLENTY of time to dry.
Hard2Find
08-16-2004 08:47 PM
