Disconnecting the secondary o2 sensor
Im replacing my o2 sensor in my cat tomorrow, and have got a quetion. Last time I was under there, it didnt look like there was any way to actually disconnect it at a plug. Where the hell do I go to disconnect it? Help would definately be appreciated.
Re: Disconnecting the secondary o2 sensor (PhoebeusFenix)
trying following the wires until you get to the plug. that's what I would do. honestly i can reach both plugs for my o2 sensors just by popping the hood.
good luck
post your set-up
good luck
post your set-up
Re: Disconnecting the secondary o2 sensor (Smith Wise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smith Wise »</TD></TR><TR><TD CLASS="quote">trying following the wires until you get to the plug. that's what I would do. honestly i can reach both plugs for my o2 sensors just by popping the hood.
good luck
post your set-up</TD></TR></TABLE>
Same here. I dont see why your plugs would be that hidden. Maybe because my cat was right under my manifold. I dont see why it would be that mcu harder to find on a car with the cat under the car
good luck
Re: Disconnecting the secondary o2 sensor (specv5150)
because it blends in with the underside.
its also directly above the cat and if you touch it it feels stiff like the coating underneath
amej8
05-28-2008 02:34 PM
Art Vandeleigh
03-29-2003 09:56 PM
lilxvtecxpwr
07-04-2002 01:20 AM
