difficult to start when cold..
Old 02-23-2010, 10:00 AM
New User
sharkrider's Avatar
Default difficult to start when cold..
hello, new here, I've done a search, but like the other forums and the rest of the net there is so much info, it may be easier if I describe my problem and someone knows what it is, rather than surf for the next 2 months,appreciate the help
I have just bough a civic 1.6 ls (1997) the CEL light is on (which I knew before I bought, but at £360 I didn't expect much) the car runs perfect when warm, but is very difficult to start when cold, I will be checking the obvious (plugs ect ) at the weekend, the battery will turn it for 5 or 6 times before it starts, so I guess thats ok...
cold weather in the morning (it about -2c in the morning here at the mo) you turn the key, and it turns and fire straight away, but then dies. you need to do this about 5-6 times before you can "catch" it with the gas and keep it running. as soon as its been running a few minutes its fine. the temp gauge reads correctly, and it doesn't overheat, there doesn't appear to be any other engine issues (rest of the car isn't bad!)
I assume its a sensor of some kind, as it simply appears as if the ECU thinks the engine is warm all the time!
Any ideas? (without me having to go to a honda dealer and pay more than the cars worth to find the problem!)
thanks in advance
the.hamburglar
05-02-2006 09:27 AM
oilguzzler
12-19-2005 02:42 PM
hlee5363
10-10-2005 01:46 AM
extracrunchie
09-01-2004 11:10 AM
Quick Reply: difficult to start when cold..
