Did a compression test on my EK GSR, not sure about results?
Old 10-27-2010, 05:14 PM
sdobson910's Avatar
Default Did a compression test on my EK GSR, not sure about results?
This is a bone stock gsr swap into 99 ek, only cell is for no cat. So I pulled the 15a fuse from under the hood and pulled all spark plugs (they look fine not running lean or rich) then hooked up comp tool floored gas pedal and wrote down numbers.
cyl 1: 170
cyl 2: 165
cyl 3: 165
cyl 4: 160
Now Im happy that the numbers are close but they seem low. The motor still runs great does burn coolant which im allready going to replace the head gasket and new arp studs. My question is could the ambient temperature be causing these low numbers, im also having my valves adjusted soon i dont know if that could figure in. I have searched and searched but most people dont have similar numbers, their numbers are more like 200,195,130,195. I want to boost in the near future but not if the motor cant handle it. Any suggestions would be great.
Thanks
Old 10-27-2010, 05:45 PM
Former User's Avatar
Default Re: Did a compression test on my EK GSR, not sure about results?
How much do the numbers rise if you add a tablespoon of oil to each cylinder?
Old 10-27-2010, 07:03 PM
EFstyle's Avatar
Also, was engine at operating temp?
Old 10-27-2010, 07:25 PM
93egSLEEPER's Avatar
Those look more like LS numbers. GSR's typically are around 190-200.
What the 2 guys ahead of me said is also VERY important aspects as well.
Old 10-27-2010, 07:50 PM
sdobson910's Avatar
Engine was at operating temperature. Outside temperature is like 50 degrees so I wasnt sure if that would make a difference. Havent tried the oil I can try that in the morning and post results.
MarkCayabyab
10
10-29-2013 06:18 PM
fast2camciv
08-31-2007 09:23 PM
h8ted ek
04-08-2007 06:44 PM
blakacintegra
10-27-2006 03:07 PM
Doogie Howser
09-15-2002 05:26 PM
Quick Reply: Did a compression test on my EK GSR, not sure about results?
