depo foglights?
depo foglights?
ok, i have jdm foglights(real-not depo), and a jdm switch, but i recently found that i bought a depo harness. anyone have the intstuctions to wire up depo foglights cuz honda's instructions are unclear, and wrong for the harness. thanks.
Re: depo foglights? (hondaj05)
the oem and depo foglights are wired up differently. the oem gets power from the fusebox and the depo gets power from the battery. the depo instructions won't help you, they basically cut and pasted from the official oem instructions so it doesn't mention connecting to the battery, had to figure that one out on my own.
hope that made sense, i'm tired
Yes, it can work with OEM fogs and switch. The harness is just a bunch of wires that give power to the fogs. There's nothing special about OEM wires. The plugs wont match up though. But if you put spade connectors on the harness for the fogs and somehow connect wires to the switch, it will work.
Re: depo foglights? (BlueIntegraBoy)
what im really lookin for is a write up on where to plug the wires into,the switch came spliced into the harness, but other than that the wires on the inside of the car are a loss to me. i have the blue and black wires spliced into the foglights themselves, and the one black wire comeing from the harness in the engine bay grounded. and another underthe dash. the blue wire is coming trough the firewall. then there is a relay, switch, and (the most confusing) are a red and white wire that come out next to the steering wheel when the harness is placed where it needs to be. thanks for the response
Does it have a brown single pin connector? This one goes to the fusebox.
I believe fuse #19 is the headlight. So it will only get power when your headlights are on IF you put it in slot #2 (2nd from the right). If you want your fogs to turn on whenever you push the button, connect to slot #5, all the way to the left.
no, nothing like that, just what i mentioned. im bout to say f it, sell the harness back on ebay, and wire them to the city lights so when ever i turn those on, theyll come on. hows that sound?
well its 2am here, and the car is in the garage in the back, so im going to bed, but i really appreciate your help dude. thanks. ill try and post pics tomarrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Take a pic of the harness. I'm pretty sure those go to the accessory slots on your fusebox. If they don't fit in the slots. Cut off the connectors and use female spade connectors.</TD></TR></TABLE>
my egay harness came with a female spade connector, worked well for me.
dapdabbin
11-22-2012 12:40 PM
amej8
10
05-21-2007 08:02 AM
Matty.
14
01-02-2006 03:49 PM
