Denso Radiator
Denso Radiator
hello honda-techers,
I would like to know if you could recommend any radiator that is similar to Denso radiator which has a part no. like this "19000-PO3-9031". It's labeled "Made in Malaysia" with another number "MA122000-2813 5R" in it. It also has a label marked ">Honda PA66-GF30<". Mine start leaking coolant at the top and bottom part.
Re: Denso Radiator
Its been 10K and no problems, part is exact fit.
Oh look, I can change this
Re: Denso Radiator
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-your-guide-buying-quality-aftermarket-maintenance-parts-your-civic-3114911/ ... but I don't know what you'll be able to find locally in your Malaysian market.
Re: Denso Radiator
this morning i drove to one of the local workshop specializing in radiator & exhaust, and they
just replace the upper cover of the tank(the one i mention with all the part no. & label). I ask them is there anything inside the tank they need to replace, they said no. they said it's the top part that causing the leakage..
#1 Super Guy
Re: Denso Radiator
You can buy the OEM radiator straight from Denso for much cheaper in a Denso box. Look up the Denso part number on the Denso aftermarket website. Then plug that part number in at sparkplugs.com
http://www.densoautoparts.com/find-m...icle-selection
http://www.sparkplugs.com/category.aspx?zcid=957
Re: Denso Radiator
curious question, are the 96-98 vs 99-00 denso radiators the same? cos the part numbers are different :
http://www.hondapartsunlimited.com/o.../19010-p03-505
http://www.hondapartsunlimited.com/o.../19010-p2f-a01
also on the densoautoparts website it only has a listing for 99-00 denso radiator for the civic SOHC.
