Radiator???
Old May 11, 2003 | 05:43 PM
TegLover4life
Guest
Posts: n/a
Default Radiator???
there is coolant leakign out and i tried that radiator plugger but that didnt work... my temp gauge is staying down but im not sure what it is.
Old May 11, 2003 | 07:34 PM
cjohnson_2's Avatar
Default Re: Radiator??? (TegLover4life)
Id guess its the normal crack in the radiator that happens so frequently. its probably just not big enough to leak enough out yet to mess up your temp guage YET. Id suggest finding where its leaking and if its the radiator get it fixed.
Old May 11, 2003 | 07:40 PM
timmy8151's Avatar
Is your radiator the OEM one? If it is, then most likely there is a crack on the plastic top of the radiator. You can try putting some epoxy over the crack, but that's only a temporary solution. Most OEM radiators tend to crack at around 100k miles.
Old May 11, 2003 | 07:47 PM
Da Integra's Avatar
i would take the radiator to a radiator shop and have it pressured checked to see if there are any leaks. doesn't cost that much i did mine for like $20 bucks
Old May 11, 2003 | 07:54 PM
WiggiE's Avatar
New User
Default Re: Radiator??? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Is your radiator the OEM one? If it is, then most likely there is a crack on the plastic top of the radiator. You can try putting some epoxy over the crack, but that's only a temporary solution. Most OEM radiators tend to crack at around 100k miles. </TD></TR></TABLE>
Old May 11, 2003 | 07:56 PM
TegLover4life
Guest
Posts: n/a
Default Re: Radiator??? (WiggiE)
yeah its a plastic POS i just put on my apexi last friday and noticed that it was leaking i have only drove it a little to try to see if that plugger ish worked... it didnt but oh well time to get it fixed. then i get to enjoy the n1
sdinteg
Jun 1, 2010 11:26 PM
charms119
Jun 19, 2005 07:48 PM
tkHBseries
Feb 19, 2005 06:48 PM
Superhatch
24
Sep 20, 2004 10:13 AM
GTEater
Aug 30, 2001 03:36 PM
