delsol fuel pump
Re: delsol fuel pump (bmrgold)
You have to take out the rear storage compartments- Youll only need a phillips screw driver then under that there is a panel you remove to gain accease to the top of the gas tank. After thattttttttttttttttttttttttttttt its a piece of cake, cause the fuel pump is internal i belive but im not certain, just remember to use brass punches to remove the ring if any because brass wont spark which could be bad cause gas fumes + spark = toasted car especially if your going at it thro the accease panel which i would. Also am empty fuel tank is more dangerous then a full one because of the spark issue. But seriously its not that hard to get at. should take you no more then 20 minutes having no clue what your doing. The spark isssue well just be carefull and use common sense. Roll the windows down, do it in an area with plenty of ventilation ext.
uberEFtuner
05-28-2010 10:22 PM
