how to remove fuel pump.?
Old Dec 29, 2004 | 04:52 PM
rolled.totaled's Avatar
Default how to remove fuel pump.?
i put some bad fuel into my tank and i'd like to take it out. problem is my gas tank does not have a drain bolt so i have to remove the fuel pump on top to gain access to the inside. the only thing in my way now is the fuel pump/tank cap atop the tank.
its about 5 inches in diameter with 69lbs ft of torque. honda has a specific tool for this but i don't exactly have a means of driving there right now, and borrowing it wouldn't seem likely.
has anyone else removed it before without the tool? i'd really appreciate any feedback. thanks.
Old Dec 29, 2004 | 04:56 PM
DIFFUT'S INC.'s Avatar
Default Re: how to remove fuel pump.? (rolled.totaled)
get a holes and suck it out
Old Dec 29, 2004 | 05:10 PM
Default Re: how to remove fuel pump.? (DIFFUT'S INC.)
i tried siphoning it out through the regular fuel hole but the hose won't penetrate through to the tank. i can feel a metal obstruction when i try to force it..
Old Dec 29, 2004 | 06:44 PM
finally! i got it off and siphoned out the bad fuel(diesel, i know i'm an oxymoron). i put in injector cleaner and regular fuel but now the motor will only crank not start. it started yesterday when i was troubleshooting it.. anyone know if i just need to keep cranking it?
jastonian106
Feb 28, 2015 09:03 PM
sc0braj
Oct 4, 2008 02:15 PM
Jonathan_ED3
May 20, 2008 03:04 PM
LudemanDan
Mar 19, 2007 11:00 AM
