Delay after turning key before car starts
Old 04-19-2010, 12:45 PM
hotcivicsi's Avatar
Icon6 Delay after turning key before car starts
Issue just started a couple weeks ago. Seems to happen when car is cold. All light turn on when I turn the key and there isnt any noise just 1 5 seconds delay maybe till car actually starts up. Battery is newish and ground cables are good. Remote starter doesnt work with one click it takes a couple tries before the car actually turns on.
98 Civic x/ LS motor - 5spd
Any suggestions?
Sticky starter?
Thanks
Mike
Old 04-19-2010, 01:34 PM
RICKSAUTOMOTIVE's Avatar
Default Re: Delay after turning key before car starts
check your head gasket. could have coolant getting in the cylinders and having harder starts. your simpton description is text book for a head gasket leak. after checking the block with a block tester you will know if you just have an ignition issue
Old 04-19-2010, 02:21 PM
hotcivicsi's Avatar
I'm not loosing any coolant or having idle issues. From other posts I've browsed through a head gasket issue was never mentioned. Car starts fine after its warmed up but I dont know if that would rule its out.
Em1Dustin
33
03-07-2018 06:46 PM
civicb16eg
21
03-12-2012 11:12 AM
jvaughn
07-18-2008 11:33 AM
dmj
05-12-2008 12:50 PM
Quick Reply: Delay after turning key before car starts
