del sol rear firewall??
hey guys im tryin to install a stereo in my del slo, but i dont know where hole is in the rear firewall. tried searching but nothin comes up.. if anyone has info or pics that be great
TIA
TIA
Re: del sol rear firewall?? (TurboSpirit_DC2)
if ur trying to wire up a sub in ur trunk, there are holes on the ends of the firewalls, on both sides of the car so u get direct access into ur trunk. Just look where the radio antena cable goes. Thats where the hole is. I think its actually just open, not even a whole.
dont drill a hole, it will hit the glass when down.....use the seam at the bottom, it is just large enough to fit, use a hanger if you need help
The bottom right and bottom left corners just under the carpet you can get the wires through. I just put in a mtx system with 2 10's behind the seats, and then 2 amps mounted on the rear firewall in the trunk. Looks clean. Used the capet to hide the wires and made everything hidden.
Kyle.
Kyle.
mish__
05-10-2012 12:07 AM
Kod Sol
07-01-2005 08:24 AM
