del sol base
Old 06-01-2002, 08:46 PM
mooseknuckle's Avatar
Default del sol base
Does anyone have the engine code, and the specs to a 97 base del sol? Thanx
Old 06-01-2002, 11:20 PM
robinson's Avatar
Default Re: del sol base (nontec)
if you are talking about a USDM Del sol, there are not any after 96. So assuming that yours is a 96 than you have the D15B7. 108 hp SOHC piece of crap.
Old 06-02-2002, 02:54 AM
NevadaSol's Avatar
Default Re: del sol base (HS killa)
Actually that's not true.
The del Sol was available in the states from 93-97, and in Japan from 92-98. The VTEC sol with the b16a was available from 94-97 in the US, and 93-98 in Japan.
The base '97 model would have the same motor as what is in the DX civics, the 1.6 SOHC non-VTEC, with, yes, 108hp.
http://www.teamdelsol.com/faq/faq.htm#years
Old 06-02-2002, 03:45 AM
97hb's Avatar
Default Re: del sol base (NevadaSol)
My 97 civic dx came with a powerful 106hp to the flywheel, and massive 103lbs of torque
Old 06-02-2002, 06:17 AM
escapist13's Avatar
Default Re: del sol base (97hb)
Hey, that's only 8 less than a B16.
Old 06-02-2002, 07:51 AM
im pretty sure the model is a Del Sol S... so then whats the specs with that one
Old 06-02-2002, 09:56 AM
NevadaSol's Avatar
MODEL - 97 S
Engine Type/Displacement: SOHC 1590cc
Compression Ratio: 9.4:1
Horsepower (hp net): 106 @6200
Torque (ft-lb): 103 @4600
Redline: 6900 rpm
Curb Weight lbs(man/auto): 2,302 / 2,388
1/4 mile (sec): 16.9
1/4 mile speed (mph): 82.3
Top speed (mph): 115
If you need anymore info, go to http://www.teamdelsol.com , and click on "FAQ"
Old 06-02-2002, 07:28 PM
B-series Assassin's Avatar
Default Re: del sol base (escapist13)
Hahahahah.
Old 06-02-2002, 07:57 PM
97hb's Avatar
Default Re: del sol base (B-series Assassin)
G-town representing
4door93civic
11-22-2006 03:12 PM
kydoster
03-15-2006 06:58 PM
89JDMcrx
05-22-2004 11:16 PM
96civich22
01-16-2003 06:26 AM
theguy003
06-07-2002 05:15 AM
Quick Reply: del sol base
