del sol base
Re: del sol base (HS killa)
if you are talking about a USDM Del sol, there are not any after 96. So assuming that yours is a 96 than you have the D15B7. 108 hp SOHC piece of crap.
The del Sol was available in the states from 93-97, and in Japan from 92-98. The VTEC sol with the b16a was available from 94-97 in the US, and 93-98 in Japan.
The base '97 model would have the same motor as what is in the DX civics, the 1.6 SOHC non-VTEC, with, yes, 108hp.
http://www.teamdelsol.com/faq/faq.htm#years
Re: del sol base (nontec)
im pretty sure the model is a Del Sol S... so then whats the specs with that one
Engine Type/Displacement: SOHC 1590cc
Compression Ratio: 9.4:1
Horsepower (hp net): 106 @6200
Torque (ft-lb): 103 @4600
Redline: 6900 rpm
Curb Weight lbs(man/auto): 2,302 / 2,388
1/4 mile (sec): 16.9
1/4 mile speed (mph): 82.3
Top speed (mph): 115
If you need anymore info, go to http://www.teamdelsol.com , and click on "FAQ"
