del sol b16 auto to stick conversion...Help!
swapped the motor runs good no code. but there is some problem engine check light, battery light, and P light which was used in automatic are still on. The stock ecu chipped to work with b16 motor 5spd. does anyone have any clues..! if you're not sure...please don't post
Re: del sol b16 auto to stick conversion...Help! (acuteviet)
so are you saying, your using a chipped ecu(the automatic one)? and are you using the automatic gauge cluster?
SOHC_Brian
03-25-2004 12:14 PM
Luserkid
01-25-2004 06:44 PM
