Del Sol anti-sway bar on EX Coupe?
What is necessary to get an anti-sway bar from a del sol to work on a 93 Civic EX Coupe?
I compared the suspension from the Del Sol and a 92 Civic LX Sedan, and it seems like I'd need an adaptor/plate to attach it to the suspension...does anyone make these, or should I not bother? I got the sway bar for $10 with hardware/bushings, so I thought it'd be worth a try
Re: Del Sol anti-sway bar on EX Coupe? (ion_four)
ttt...somewhat related...
is the rear suspension on the del sol Si (the one with discs) the same as that on the integra, so that I could bolt it on without any probs and thus have the sway bar AND rear discs on my 93 Coupe?
Yes on the rear brake note. Need the rear LCA and all the other equipment related to the sway.
On the front, should fit with no problem, just need to make sure you have a hole in the front LCA for the end link to bolt into, which you should because you have an EX. Get all the brackets and such from the Del Sol sway and everything should bolt over.
Re: Del Sol anti-sway bar on EX Coupe? (acura_typer)
So...I realize this seems ghetto...but, if I use the suspension from a Del Sol on one side and a Teg on the other will they be the same? Or, is there some kind of difference on there that would make my car handle all weird?
This is for the REAR suspension only. I am keeping my front the way it is (already have the 10.3" discs and stock sway bar).
[Modified by ion_four, 7:48 PM 1/9/2003]
724chris
03-20-2011 06:21 PM
dj theoretic
04-15-2008 04:50 PM
idriveadelsol7
04-13-2005 09:25 PM
