delsol=integra?
delsol=integra?
Are the rear suspension members (control arm/trailing arm, etc.) on a Del Sol Si/VTEC (with rear discs) the IDENTICAL to those on a 94-01 Integra?
I want to put discs on the rear of my Civic EX Coupe and I can get one side from a Del Sol for almost nothing and all the stuff but the trailing arm for the other...as it was damaged in an accident...
Could I replace the trailing arm with one from an Integra and not have a problem? I ask this because I can also get a deal on the Integra trailing arm, that's why I'm not hunting down another Sol arm...
any help is appreciated!
Re: delsol=integra? (ion_four)
Not sure about the rest of the stuff, but the LCA on certain del Sol Si models (93-95) lacked the "nubbin" mount for the sway bar, so can't be used with a sway bar set up. 94-97 del Sol VTECs and 96-97 del Sol Si's are ok though.
Steve
Steve
Re: delsol=integra? (stevecockrill)
Thanks for the reply.
The suspension I'm looking at DOES have the "nubbin" since I got the sway bar off there already I'm wondering if the del sol trailing arm with the nubbin is identical to the integra one with the same, so that I could use the sol's trailing arm/hub on the driver's side and the integra's on the passenger (passenger side of del sol was T-boned and bent). Do you think I would have any issues with this, ie. if they aren't identical?
okay, I called a honda dealership and an acura and this is what I found:
Passenger-side trailing arm for a 96 Del Sol VTEC = #52370ST7G91 (G90 for driver's side)
" " 96 Integra GSR/LS = #52370ST7G91
Driver's side " "96 Del Sol Si = #52370ST7G61
The part's guy at honda said that they are the same part, but that the number is different either for tracking, or because one or the other has an ABS harness or something...
So, these seem to be the same, can someone verify this?
::EDIT::
My previous post implied that these weren't the same parts, but now it seem they are...
[Modified by ion_four, 8:54 PM 1/10/2003]
::EDIT::
SiR Koopa
09-28-2007 03:50 PM
idriveadelsol7
04-13-2005 09:25 PM
