d16z6 wont start
d16z6 wont start
recently, my car hasn't been starting, strictly in the morning. i also noticed it was cold outside everytime it didn't start. when i turn the key, it doesn't crank or anything, no sounds coming from my car at all. what could be the problem? bad timing? starter? thanks
RIP 1032
Re: (EJcoupe)
i'v was having the same problem. every morning i'd crank and crank and nothing. turns out it was my starter. take it to autozone or something. i hear they will check all your electrical stuff for free.
Re: d16z6 wont start (EJcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe »</TD></TR><TR><TD CLASS="quote">recently, my car hasn't been starting</TD></TR></TABLE>
you kinow what this means. time for a swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mantic6t9 »</TD></TR><TR><TD CLASS="quote">You may also want to check your main relay.. I had this problem in my si hatch. It costs $50-60 to replace. </TD></TR></TABLE>
or try to check ur starter.
Re: (EJcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe »</TD></TR><TR><TD CLASS="quote">how much does a starter for a d16z6 go for?</TD></TR></TABLE>
i'd say around $50 brand new. you can get them for alot cheaper.
Re: (handa)
I'm almost 99% sure that it's your starter. If you've got 15-30 minutes, you could yank it out & test it at Autozone as mentioned above. 2 bolts, 2 wires and out it goes.
Is your fuel pump priming? Do you hear it when you turn your key in the "ON" position? One way to listen is to look for the CEL to come on and off. Let us know
Re: (Inconclusive)
are you pushing the clutch down all the way? my car started doing that, id have to push it ALL the way to the floor before it will start now...
as far as in the mornings, is your ECU chipped? could be that the fuel left over in the cyl needs to clear out before it'll start
^^ actually, its weird because, you dont even have to push the clutch to start my car but i do anyway, and yes i push it all the way down.
ill get my starter checked on monday. and ill let you guys know
lilo_goki
11-11-2008 08:03 PM
