D16Z6 into Del Sol S Question =)
Old 11-16-2006, 12:51 PM
froger's Avatar
Default D16Z6 into Del Sol S Question =)
Hi all, I've been searching around for this topic but I've found mostly B16 swaps. I bought this engine originally for my CRX but now I don't have the car anymore. I wanted to get a del sol S and drop this in cuz it seems that the S are more abundant and Si and VTecs. =P My question is other than the engine...what else would I need to do the swap? If I get a 93 - 95, then I wouldn't have to convert to OBD2 correct? How do I wire up the vtec? and what ECU is in the del sol?
Thanks for any input! I'm sure I'll have more questions once I get this project rolling. (gotta get the car first)
Old 11-16-2006, 02:39 PM
broketuner-Sol_Si's Avatar
Default Re: D16Z6 into Del Sol S Question =) (froger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by froger &raquo;</TD></TR><TR><TD CLASS="quote">Hi all, I've been searching around for this topic but I've found mostly B16 swaps. I bought this engine originally for my CRX but now I don't have the car anymore. I wanted to get a del sol S and drop this in cuz it seems that the S are more abundant and Si and VTecs. =P My question is other than the engine...what else would I need to do the swap? If I get a 93 - 95, then I wouldn't have to convert to OBD2 correct? How do I wire up the vtec? and what ECU is in the del sol?
No, a d16z6 is OBD1, if you get a 93-95 sol, you're golden. the correct ECU for the motor is p28. It'll bolt right in, no aftermarket mounts/axles needed.
Old 11-16-2006, 03:02 PM
Orangedragone's Avatar
All plug n' play my friend. all delsols came pre-wired for vtec.
Old 11-17-2006, 07:01 AM
froger's Avatar
Default Re: D16Z6 into Del Sol S Question =) (Orangedragone)
Thanks for the info. Don't flame...this is probably a noob question. What do you mean when it's pre-wired for vtec? Also instead of doing the engine swap can I just swap in the Z6 head and keep the bottom block?
94delsol6428
20
10-02-2012 07:10 PM
NSXOTIC
08-24-2008 06:16 PM
PaImportTuner
12
02-16-2005 02:05 PM
lYellowDragonl
10-18-2004 06:25 PM
RexLine
11-23-2003 08:09 PM
Quick Reply: D16Z6 into Del Sol S Question =)
