d16z6 help
d16z6 help
ok i got two things
1. when i first start the car and i try to rev it like hesitates a little but then goes, when engine warms up it is fine again
2. also wen cold i get a nice low idle but wen warmed up i idle at about 1k or 1200 not sure.
what can be the possible causes?
thanks appreciate the help
You throwing any check engine lights?
The high idle sounds like either a vacuum leak or the FITV needs cleaning (though with a vacuum leak it would be revving high when you first start it, too).
The hesitation sounds like it could be a TPS issue...
Blah, no codes?
Blah, no codes?
martingouda
11-24-2005 11:54 AM
CimorelliCRX
07-27-2002 10:07 AM
