cel light help
cel light help
ok i got a few different codes and one of them is 11 i do not see it on the list can anyone help? or heres a link to my video maybe im wrong
http://youtube.com/watch?v=Fbwyl6JgGT0
Well I have good news and bad news.
I found the CEL code 11. Thats the good news.
Bad news is it means your ECU is bad, or at least your ECU thinks its bad. Try borrowing a new ECU and see what happens.
EDIT: I just watched your video, and I only saw codes 6, 19, and 21.
Modified by OMGWTFBBQ! at 12:43 AM 8/5/2008
Re: (OMGWTFBBQ!)
I don't see an 11 there. I see a 21 easily mistaken for an 11.
I see a 21, a 19, and a 6.
The reason it appears like you're getting an 11 is because you're not doing it right.
You're supposed to jump the connector first, then turn the key to the accII position. As soon as you turn the key it starts cycling through the CEL's that its throwing. It looks like you just hit it after the first 10 appeared.
The order goes as follows:
"11" >> 6 >> 19 >> 21 >> 6 >> 19 >> 21
The cycle repeats itself infinity, from lowest to highest.
The order is 6, 19, 21, and repeats twice - you caught it at the end of 21 at the beginning (which you thought was 11), then it repeated to 6, it wouldn't do that, it goes from lowest to highest and loops, every time.
There is no CEL 11 there.
Try putting the paperclip in the jumper then turning the ignition and I guarantee you'll get 6, 19, 21. The ECU works lowest to highest, not a random order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">Well I have good news and bad news.
Modified by OMGWTFBBQ! at 12:43 AM 8/5/2008</TD></TR></TABLE>
I've never seen an OBD-I Honda throw a "general" code.
EDIT:
Ah, nvm, you just edited after I hit reply.
EDIT:
mafia
06-25-2007 08:22 AM
Exxel82
05-01-2007 08:15 AM
1990AccordEX
11-28-2006 09:00 PM
