D16y8 swap in 96 DX
D16y8 swap in 96 DX
I have a 96 civic i had a D16y7 in it i did a mini me put a y8 head on it and worked for a while never ran right it jumped idle like it was had a vaccum leak.. I Just bought a D16y8 full motor...
And i want it to run right as if it was the motor that came in the car
Do i gotta finda EX In a junk yard and steal i mean buy the wiring harness or clips or sum to make it run like i want? im still OBD2 i dont wanna do OBD 1 converson Till i Pass emissions..
What all do i need to do to make the car run like its supposed to... cause i wanna keep it like normal till i get my LSV built
Re: D16y8 swap in 96 DX
yeah im not worried about that Motor no more I Got a Rod knock... lol so now im on a misson to put another Y8 in...
Ill check to see where this one came out of... bought it from a friend... but
Should i Cut all the clips off a EX
Technical Hero
You will have to run the wiring for VTEC solenoid, VTEC pressure switch, and knock sensor. You'll also have to extend one or more of your O2 sensors. The Y7 also has a 3 wire IACV so unless you converted it earlier you'll have to convert your 3 wire plug to a two wire.
Lasty K
27
11-01-2017 09:03 AM
Dballa102587
06-20-2008 07:06 AM
