D16y8 TO D16y7 SWAP!! NEED HELP?
I currently purchased 2 cars. 96 Civic EX and a 98 Civic DX. both stick 2dr. The 96EX has a F-UP motor, so i was gonna swap out the y8 for the y7 . I wanted to know if anyone knows if its a direct bolt up, as far as transmission, and ecu, etc...... NEED FEEDBACK. Please Help!!!!
Mr. Badwrench
Re: D16y8 TO D16y7 SWAP!! NEED HELP? (Dballa102587)
off the hit dx 3 wire iac
ex 2 wire iac.
how bad is the engine?
why not take the y8 head on the y7 bottom put it in let it eat?
everything will swap.
ex 2 wire iac.
Re: D16y8 TO D16y7 SWAP!! NEED HELP? (boostedcivicsir)
Everything should bolt in fine, both cars are obd2a so wiring should not be a problem. Search for a website it's called ff-squad something where you can find some pinout diagrams. Like boostedcivicsir said you are going to have to switch 2 wire(y8) to 3 wire(y7) IACV, check out those obd2a pinout diagrams it's not very hard to figure out.
Lasty K
27
11-01-2017 09:03 AM
