d16y8 intake mainifold on d16y7
I just want to double check that the auto manifold is a direct swap i know i need to fill the air injection holes im just wondering about the throttle body sense it is a auto it has the iacv on the throttle body. I believe all i need to do is put it on and go is that correct.
Re: d16y8 intake mainifold on d16y7
you are right, the auto Y8 manifold and TB won't need modification (other than injector air ports like you said). you may need to pull some slack out of the harness to get everything to plug up. it's been 2 years or more since i swapped mine so some of the details are a bit fuzzy.
Technical Hero
http://www.---------.com/diy-forum/2...swap-pics.html
enter one cam only.com where the dashes are above
titi_vtec
06-29-2010 07:59 PM
awdriscol4
07-19-2005 07:33 AM
J Rob
05-15-2005 06:42 AM
atc5
14
11-23-2004 06:37 PM
Quetzolcotl
10-23-2002 11:52 PM
