d16 swap to b16
Old 01-10-2005, 02:34 PM
EJ8 GSR-T's Avatar
Default d16 swap to b16
Is there any welding involced in swapping a d16 to a b16? what im wondering is the motor mount situation...any help?
Old 01-10-2005, 02:37 PM
JBG's Ferio's Avatar
Default Re: d16 swap to b16 (userdead626)
no welding is needed.
Old 01-10-2005, 02:39 PM
civicminded92's Avatar
If you can use the search button, and get creative you can find the answers that you seek. It's in the upper right hand corner of the page. Try it out, get used to using it, it is a great tool
Searched for "b16 mounts ", came up with 9 results in archives, third from the top yeilded this info:
1.) Rear transmission mount bracket - 1999-00 Civic Si - 56827-S04-N10 $28.86 Reuse the stock rubber mount.
2.) Driver's side engine mount bracket - 1999-00 Civic Si - 11910-P30-000 $40.12. Use the stock Civic 96-00 bolt studs and all other stock parts at this location.
3.) Front transmission mount bracket - 1994-01 Integra. Use the stock Civic 96-00 end rubber mount and bolt stud.
4.) A/C mount bracket - 1993-97 Del Sol. Use the stock Civic 96-00 A/C compressor.
5.) Upper transmission mount bracket - Stock Civic 1996-00.
Old 01-10-2005, 03:15 PM
Yumm Tum Yummm's Avatar
you dont need any welding if you get the b16 complete swap everything is there for you to install into you car
Old 01-10-2005, 04:03 PM
EJ8 GSR-T's Avatar
Default Re: d16 swap to b16 (EJ_FaNaTiK_22)
see my prob. is i dont feel really comfortable installing a motor myself, but theres nothing more i want than to learn, and i learn by doing, but you think this may be to big of a risk?
Old 01-10-2005, 04:04 PM
jlacoy82's Avatar
Do like I'm doing, start small, build the head! Or if you can afford the down time, build the bottom end of the d and go high compression!
bamboosted
05-12-2010 10:06 AM
drowzysleeper
09-17-2005 09:00 AM
blueintegra90
06-11-2004 04:03 PM
crxhoutx
11-19-2003 04:32 AM
Quick Reply: d16 swap to b16
