size of injectors
Old Mar 20, 2005 | 02:32 PM
Tdawg1030's Avatar
Default size of injectors
Im trying to put together a turbo kit for my D16. does anybody have any suggestions on what kind of injectors i should get, like 450cc??
Old Mar 20, 2005 | 02:35 PM
oxSLEEPERxo's Avatar
Default Re: size of injectors (Tdawg1030)
what is ur hp goal? need more info
Old Mar 20, 2005 | 02:36 PM
Tdawg1030's Avatar
Default Re: size of injectors (oxSLEEPERxo)
my hp goal is 300. im planning to redue internals, and mabye even sleeve it later on.
Old Mar 20, 2005 | 02:51 PM
NJIN BUILDR's Avatar
http://www.rceng.com/technical.htm#WORKSHEET
Glenn
Old Mar 20, 2005 | 02:55 PM
SPL Dan's Avatar
Default Re: size of injectors (NJIN BUILDR)
89-91 Turbo II RX7 injectors are High Impedence 550cc and can usually be had for 100-150 dollars .
DSM 450cc usually a bit less . You will need a resistor box for the DSM's
Old Mar 22, 2005 | 09:58 PM
Evo-man@20psi's Avatar
450,s are a good start if running rich just use afc to lean it out
Old Mar 22, 2005 | 10:36 PM
ndogg's Avatar
Default Re: size of injectors (Blue00vtecsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue00vtecsi &raquo;</TD></TR><TR><TD CLASS="quote">450,s are a good start if running rich just use afc to lean it out </TD></TR></TABLE>
ya dood AFC hack is the b3st!1
forcefedferio
Dec 25, 2005 12:20 PM
sinatra
41
Aug 7, 2004 08:01 AM
Integra808
Jul 31, 2003 10:38 PM
arsenaldragster
Apr 22, 2003 07:09 PM
legendboy
Aug 19, 2002 01:38 PM
