D15B7 Ignition Distributor fits D16Z6?
I'm in the middle of a mini-me D15 block D16Head... the Ignition Distributor from the D15 will fit the new Head? Is there some way to make it fit...?
Re: D15B7 Ignition Distributor fits D16Z6? (eortizr)
I think you need to cut off one or two legs, but I don't know if you are going to be able to get correct timing, I would search and I know it has been done.
Re: D15B7 Ignition Distributor fits D16Z6? (BauleyCivic)
you have to cut off the leg clossest to the dashbord it should be ok but make sure you tighten the other two
1 Post
Re: D15B7 Ignition Distributor fits D16Z6? (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">I think you need to cut off one or two legs, but I don't know if you are going to be able to get correct timing, I would search and I know it has been done.</TD></TR></TABLE>
anyone else?
anyone else?
melissashelton1
02-04-2010 05:16 PM
warchieft2k
03-01-2007 11:18 AM
bolt, d15, d15b7, d16z6, distributer, distributor, distrubutor, engine, fit, fits, igniter, ignition, ignitor, work
