car starting problems
i installed a new starter, new ICM unit, new ignition coil and yet my car still wouldn't start. i also put in a new battery. What could be the problem? My car hasn't been running for almost two months now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aljayALLday »</TD></TR><TR><TD CLASS="quote">my car sounds like its turning when i start it but you don't hear it crank. </TD></TR></TABLE>
what????
you totally contradicted yourself
what????
it could also be ur fields vtec controller....even though it's off...it still messes up ur ecu wiring...take it out and reconnect all the wires u cutted for the fields vtec controller n try ur car.
whenever i try to start my car, it sounds like its turning but slowly. Like it has no power. could it be that i'm not getting enough fuel? if so, how do i check if its getting fuel?
if it sounds weak n no power it could be the battery or alternator
to check fuel going through u can have a friend turn the key to the 2nd notch and u put ur ears next to the fuel rail and u should be able to hear fuel going through....just turn the key back n fourth to the 2nd notch n see if u hear any fuel going to the fuel rail
Audio28
Jul 3, 2003 05:33 PM
