d15b7 wont startup!!
my del sol sat outside for 2 days while i drove my talon tsi for a whille and now it wont start WTF!!!???? got spark, got fuel, good timing anyone
Re: d15b7 wont startup!! (4ghatch)
****, you sure your batterys not just old, and isn't holding a good charge? My **** was doing that on my old battery, and my dad's is now too.
Re: d15b7 wont startup!! (BlackoutVTi)
lol im not a retard!!! the starter throws fine and all im going to swap the dizzy in a bit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ghatch »</TD></TR><TR><TD CLASS="quote">lol im not a retard!!!</TD></TR></TABLE>
yes u are
yes u are
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ghatch »</TD></TR><TR><TD CLASS="quote">lol im not a retard!!! the starter throws fine and all im going to swap the dizzy in a bit</TD></TR></TABLE>
Hey, just don't know everyone on the site (how can ya), a lot of people DO just overlook the answer that's right in front of them. Sorry dude. So, have you figured out what it is yet?
Why are u swapping the dizzy when u said you had spark??? Check your ignition switch by hot wiring it. A bad ignition switch will try and start the engine but won't keep it running.
Re: d15b7 wont startup!! (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly »</TD></TR><TR><TD CLASS="quote">Why are u swapping the dizzy when u said you had spark??? Check your ignition switch by hot wiring it. A bad ignition switch will try and start the engine but won't keep it running.</TD></TR></TABLE>
number 2 didnt spark at all
number 2 didnt spark at all</TD></TR></TABLE>
Usually people include **** like that in their OP when they want help.
So yeah, let us know how the new dizzy works out...
Re: d15b7 wont startup!! (Syndacate)
A little bitterness in that post, but true. Add as much information in your original post as possible so we can better throw our stupid suggestions at you . As you know, were all genuises here on Honda Tech.
Where's the spark not reaching? Before or after the plug wire?
"Where's the spark not reaching? Before or after the plug wire? "
that is a good question i dont know but i just pulled and swaped the dizzy it fired right uo for me so my guess is that its was the coil since the cap and rotor were 100miles new
try spraying a lil starting fluid in the throttle body. see if it will fire up then. if that wont fire it up then you have something preventing it from starting...... main relay will also cause the car not to start. one minute it will start up, you go somewhere then the next minute it wont start. they are known for randomly shitting out for no reason.
em1mike
21
05-01-2007 04:07 PM
