Which CV Front Wheel Axle will fit my car?
Okay guys, I have a 1995 Honda Civic Ex Coupe. Right now I need to replace my CV Front Wheel Axle but the problem is that I don't know which will fir my car since it has a swap engine and I don't know if it has a different transmission from another car. I checked the year that has on the head and it says 98. Also is a B18B1.What should I do??
This is the engine:
This is the engine:
pm4nudes
Re: Which CV Front Wheel Axle will fit my car?
So now you google "honda y80 transmission" Tada! Now you know what car it belongs to. I'm charging you $19.99 for my assisstance. Have a good night.
Former Moderator
Axles can be from any of the following:
94-01 USDM Integra 5-speed (trim doesn't matter)
94-97 Del Sol VTEC
99-00 Civic Si coupe
The parts store dummies will probably ask you "ABS, or not?" and it doesn't matter. Get whatever they stock. Axle is identical except for the ABS ring, which can be left on.
94-97 Del Sol VTEC
Former Moderator
It could have been an "LS motor" with a 90-93 cable tranny (with mount kit) and thus would take a different left CV axle since the intermediate shafts are totally different from 90-93 and 94-01 B series.
True but who would down grade to a cable trans in a hydro car? Your point is valid but 99.9% of the time you have a hydro car w/ a swap, it will have a hydro trans. Agree?
Seagull Management
The trans doesn't matter so much as the intermediate shaft. Every so often someone will run a cable intermediate shaft and axles on a hydro trans or vice versa. It's rare but it happens.
Brandan Ngo
01-13-2019 12:25 PM
