customers eg dies out of no where need help please
working on a eg 4 door bone stock with 5 speed.
car suddenly died one day had no spark. I put used dizzy car ran afterwards just great.
week or 2 later car keeps dying out of no where wether rolling or at a stop light.
tack and temp gauge bounce around as they please at times but no idle fluxuation or anything. all smog and lines are there no vacuum leakes.
need help what diraction to take, I checked all grounds is it possible the dizzy is taking a ****?
every time the car dies it starts right up whats the problem
Re: customers eg dies out of no where need help please
The bouncing tach may suggest a bad igniter unit inside the "new " distributor.
When it won't start, is there spark? Does the fuel pump prime? CEL codes?
was a used (new to me) dizzy
it would start just fine even when it would die no cels and fuel pump prims every time
^ x2 the bouncing gauges seem to suggest so. Doubtful you'd be having a different problem that would cause that at the exact same time this symptom showed up.
http://cgi.ebay.com/ebaymotors/Tune-...ht_3527wt_1166
Try getting something like that if you can find the right kit on there. Should solve alot of problems, and save a little money.
StreetDreamS808
12
10-13-2014 07:28 PM
streetfame973
06-10-2009 10:19 AM
DeDonDeRosa
12-01-2003 04:31 PM
