CTR Intake CAM in GSR HEAD
just picked up a CTR INTAKE CAM, and was wondering if I would see and feel a diference , if i keep the stock GSR exhaust cam, and install the CTR intake cam would that be safe and ok?
Re: CTR Intake CAM in GSR HEAD (lo0nY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY »</TD></TR><TR><TD CLASS="quote">see the difference, with someone driving my car down the track...and break 13's</TD></TR></TABLE>
you must be kidding man
your gsr intake cam is designed to be used with your dual runner intake manifold. replacing the intake cam with a civic type r cam will cause you to lose some of that low and mid range power you have now.
_____________
im a jackass don't listen to me
For the finest in JDM engines and better pricing than hmotorsonline.com Click Here
[B][I] Can you hear me now? Good!!
2000 EK HB
Modified by Huggy Bear at 4:20 PM 2/5/2004
_____________
2000 EK HB
Re: CTR Intake CAM in GSR HEAD (Huggy Bear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear »</TD></TR><TR><TD CLASS="quote">your gsr intake cam is designed to be used with your dual runner intake manifold. replacing the intake cam with a civic type r cam will cause you to lose some of that low and mid range power you have now.</TD></TR></TABLE>
what if you upgraded it to a skunk2 manifold...would it make a difference then?
Re: CTR Intake CAM in GSR HEAD (slixxracing)
i almost suggested this<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slixxracing »</TD></TR><TR><TD CLASS="quote">
what if you upgraded it to a skunk2 manifold...would it make a difference then?</TD></TR></TABLE>
_____________
2000 EK HB
Modified by Huggy Bear at 4:21 PM 2/5/2004
_____________
2000 EK HB
If you drop the CTR intake cam in your car, you will notice a difference. The exhaust cam is not much bigger than the stock one, so you won't see much difference with it, compared to just the intake cam upgrade.
I highly recommend the Skunk2 intake manifold, as it will aid it making more top end power, especially with the new intake cam.
As far as hitting 13's, this is possible depending on what car it's going into, and if you can drive/have traction (decent slicks).
Re: CTR Intake CAM in GSR HEAD (boostsohfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast »</TD></TR><TR><TD CLASS="quote">I've seen a type-r intake cam with the skunk2 IM and gsr exhaust cam on a b18c1 and it did make a difference.... but not much. </TD></TR></TABLE>
Was it tuned on the dyno with an experienced tuner? Because adding a Type R exhaust cam on that set up is not going to do anymore. Might allow a bit more adjustment on the exhaust cam to allow for a powerband tailoring, but not much more. The ITR/CTR exhaust cam is not worth the money, unless you're getting a good package deal.
Re: CTR Intake CAM in GSR HEAD (fred92htch)
so you guys think ctr cams would make a difference if it's in a turbo application car? I know you probably wont be able to feel the difference but maybe the dyno can see the difference.
Re: CTR Intake CAM in GSR HEAD (Cult of Staxx)
I admit the car was never tuned and it probably had more potential... The car was not mine, it was a friends. We knew about the exhaust cam so thats why we didn't get it. My car pulled on him just about the same as before when he upgraded to the type-r cam. I will say it felt better on the top end.
If anyone in this thread is interested, I just pulled the Skunk2 intake manifold off my old blown GSR, am looking to sell it. It's in perfect condition, about to put it in the classifieds as soon as I take a couple of pics this weekend. Just a heads up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slixxracing »</TD></TR><TR><TD CLASS="quote">so you guys think ctr cams would make a difference if it's in a turbo application car? I know you probably wont be able to feel the difference but maybe the dyno can see the difference. </TD></TR></TABLE>
NA cams = no good for turbo
gsr cams are fine
gsr cams are fine
I had 2000 ITR cams (same as CTR) in my Civic with a Skunk2 ITM and the top pulled so nice, straight through 3rd and 4th.
