crankshaft pulley bolt help!!!!
Old 10-11-2003, 10:58 AM
MrEg's Avatar
Default crankshaft pulley bolt help!!!!
i cant get the damn bolt out.......i am using the MOROSO Crankshaft pulley holder and a Craftsman Breaker bar........i broke 2 sockets and 1 breaker bar.......yes....broke them!!!!!.........on the damn bolt....any ideas...????
just returned the tools for new ones.....ready to crack this biaattcchh....
any little things that i should consider to help ease this bolt removal
already tried IR Impact Tools....i even stole the best one from work with no luck
Old 10-11-2003, 11:25 AM
solo2slocivic's Avatar
get some like that once in a while.. use better tools.. ie: impact socket and good quality(matco,snap-on) breaker bar and a cheater pipe
Old 10-11-2003, 11:53 AM
axhandler's Avatar
Default Re: crankshaft pulley bolt help!!!! (mr_timluu)
I went through this not too long ago...I couldn't get it off for anything. I took it to a local honda shop and the guy busted it loose with a 3/4 inch impact. Then he just bumped it back on that way I could get it off when I got it back home. Charged me 5 bucks. Saved me tons of frustration.
Old 10-11-2003, 01:43 PM
Darth ModerVader
Padawan's Avatar
Default Re: crankshaft pulley bolt help!!!! (axhandler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axhandler &raquo;</TD></TR><TR><TD CLASS="quote">I took it to a local honda shop and the guy busted it loose with a 3/4 inch impact.</TD></TR></TABLE>
We actually bought a 3/4" gun just for this purpose, and there has yet to be a crank pulley bolt that it couldn't remove in a few seconds. It has proved well worth its cost.
Old 10-11-2003, 01:55 PM
RedlinedVTEC's Avatar
Engine in the car method: just use the 19mm lug wrench that is for changing the spare instead of breaking your ratchets on this. Place car on jack stands, just the front is fine. Insert your crank pulley tool in the opening on the crank pulley. The handle should be pointing down and to to the front of your car like : /. Now stick your 19 mm lug wrench through the opening and make sure the handle is above the axle so when you rotate the moroso tool clockwise, the lug wrench catches on the axle. Then I just take a floor jack and pump it up on the crank tool, effortlessly breaking the bolt free.
If the motor is out of the car, lock either the pulley tool or the wrench to the floor and use a breaker bar to break it loose.
Both techniques are very easy, if the motor out of the car, you might need a buddy to hold it in place for you so it doesn't move around.
Old 10-11-2003, 02:10 PM
dantastic's Avatar
i used the brakes to hold the motor still and used a 24" 19mm lug wrench. worked like a charm
nate_o
26
04-23-2024 09:28 PM
awjuhl
14
01-22-2012 04:43 PM
whitehf
12
10-13-2011 08:12 AM
ctr2007
10-07-2008 03:35 AM
JSPECHB
45
02-27-2004 11:37 PM
Quick Reply: crankshaft pulley bolt help!!!!
