Crank seal
Old 01-29-2009, 04:33 PM
mattbatson's Avatar
Default Crank seal
doing the timing belt on my 94 with bone stock 1.5.
I'm trying to get the crank oil seal out from around the crank nose (200K miles) and cannot get it out.
I have a seal puller that looks like a double sided hook, but it is made to be used when a seal doesnt have anything sticking through it.
I tried using something pointy to grab it, but didnt work.
what is the trick?
Old 01-29-2009, 04:42 PM
Bondito007's Avatar
Default Re: Crank seal
You may just have to get it out by any means you can. 200k, it may be time for a new seal any way. Good luck.
P.S. Nice vid.
Old 01-29-2009, 11:49 PM
mattbatson's Avatar
thanks,
I guess the question is, do I need to remove the oil pump to get this seal off.
If I do, would it be a good time to replace the pump on a 200k motor, or do they last longer than dirt.
Then, when putting it back on, should i put the seal in the oil pump BEFORE putting the pump back on?
Surely somebody has done this before. Can anyone help with this?
Chargerhemi06
12-04-2014 05:43 PM
91(si)hatchey
11-06-2009 12:32 AM
92civeg
02-26-2006 09:47 PM
NWHybrid
01-23-2004 10:19 PM
warwagon
09-25-2003 09:31 PM
Quick Reply: Crank seal
