Cotter pin in ball joints
Old 08-16-2013, 03:05 PM
globy123's Avatar
Default Cotter pin in ball joints
Hello. Why do upper front control arms have cotter pins in the ball joint stud in 99 Honda civic lx? Since the ball joint is tighten with a screw, is it necessary to insert the cotter pin in the ball joint stud after tightening the ball joint screw?
Old 08-16-2013, 05:15 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Cotter pin in ball joints
Yes. It's not extra.
Old 08-16-2013, 05:39 PM
doublezerohatch's Avatar
dude the cotter pin stops the nut from loosening off with vibration . . . I personally (on my own cars) don't put them back (im in there couple times a month and visually inspect it. and other components, grease my ball joints, lube my brakes) but for the sake of it. . . put the cotter pins back they wouldn't be there if they didn't serve a purpose.
Old 08-16-2013, 05:53 PM
Ci-v-iC's Avatar
Parts subject to constant vibration and how heat/cold effects metal ( shrink in cold-expand in heat)...for safety reason are secured by cotter pin (imagine a wheel ripping off at any speed not to mention high).
If you think upper is less important 'cause lower holds things together...think again...it's a chain reaction...in a nut shell w/less grumble
Old 08-16-2013, 06:12 PM
10psiLsEf2's Avatar
Theyre intended to stop the nut from backing off the stud in case they become loose.
Old 08-16-2013, 06:13 PM
10psiLsEf2's Avatar
If you dont have any you can use a coat hanger and cut it. Or a metal object that will fit in there and wont fall out.
globy123
08-17-2013 03:10 PM
89efhatchcrap
Suspension & Brakes
24
02-17-2009 10:36 AM
azian21485
05-02-2005 05:48 PM
rasinhell
02-03-2005 01:47 PM
ultraforce77
07-15-2004 02:59 PM
Quick Reply: Cotter pin in ball joints
