cooling fan problem b18c type r
Re: cooling fan problem b18c type r
bump, ac fan works. does the temp cooling sensor on the head have anything to do with the fan?
thanks for the input guys, is there any way to check to see if the switches are good before I go buy a new one?
I have a spare Honda oem in now and the previous one is mishimoto low temp switch (only one year old). Maybe it possible both are bad? haha if so that's some ****!
fan troubleshooting (should work for most hondas)
https://honda-tech.com/forums/showthread.php?p=44511768
With the thermo switch connected on the engine & plugs off, use a multimeter to check for continuity on the 2 pins on the switch. It should be open when engine is cold, and it should be closed when coolant gets hot. If it proves to be working according to specs, check the connectors. If all of the above is ok, check for proper coolant circulation.
I had a mishimoto fan switch die on my shortly after install, and I talked to them and they sent me another, been fine after that.
did you bleed the system after installing the spare switch?
haha RON! I was hoping you would chime in on this, yes it comes on when the key position is ON(II).
turned out the to be the fan switch, got a new one and everything is fine. i guess the old honda oem one had gone bad from laying around and the mishimoto is just a piece of ****! thanks for the help guys
Mfoehrkolb
Honda Civic (2006 - 2015)
05-20-2018 03:00 PM
boots420
21
09-30-2007 12:29 AM
