cooling fan problem b18c type r
fixed
Re: cooling fan problem b18c type r
bump, ac fan works. does the temp cooling sensor on the head have anything to do with the fan?
Originally Posted by whoaitzbrain
(Post 47548845)
if you jumped the fan and it turned on, that indicates a problem with the switch. install a new oem fan swtich and bleed the system. you should be all set |
Losing coolant? Is the coolant actually flowing? Both hoses getting hot?
Originally Posted by grumblemarc
(Post 47549301)
Originally Posted by dpetro1
(Post 47549039)
no.
if you jumped the fan and it turned on, that indicates a problem with the switch. install a new oem fan swtich and bleed the system. you should be all set thanks for the input guys, is there any way to check to see if the switches are good before I go buy a new one? |
(Post 47549336)
I have a spare Honda oem in now and the previous one is mishimoto low temp switch (only one year old). Maybe it possible both are bad? haha if so that's some shit!
thanks for the input guys, is there any way to check to see if the switches are good before I go buy a new one? fan troubleshooting (should work for most hondas) https://honda-tech.com/forums/showthread.php?p=44511768 |
(Post 47549336)
I had a mishimoto fan switch die on my shortly after install, and I talked to them and they sent me another, been fine after that.
Originally Posted by axis11
(Post 47549839)
With the thermo switch connected on the engine & plugs off, use a multimeter to check for continuity on the 2 pins on the switch. It should be open when engine is cold, and it should be closed when coolant gets hot. If it proves to be working according to specs, check the connectors. If all of the above is ok, check for proper coolant circulation.
(Post 47549618)
did you bleed the system after installing the spare switch?
yup, sounds like a bad thermal switch. Mishimoto is not the best, OEM FTW
If you jump the unplugged 2P fan switch connector, does the fan run when the key is in ON(II)?
Originally Posted by RonJ@HT
(Post 47551133)
turned out the to be the fan switch, got a new one and everything is fine. i guess the old honda oem one had gone bad from laying around and the mishimoto is just a piece of shit! thanks for the help guys
