H22 throttle body
Old Jan 13, 2007 | 10:32 AM
Hondaen's Avatar
Default H22 throttle body
Hi
I have a buildt H22A engine with Golden Eagle intake manifold.
Power goal is 400Whp.
The stock H22A come with a throttle body that is water heated from the coolant. It seems that it is thermostat controlled inside the throttle body.
I have searched HT and the reason for the water heating ppl come up with is to eliminate freezing of the valve/throttle body. (sticky valve)
My question is, what about non-OEM throttle bodys, dont they stick ? There is no heating on them as far I can see.
Can I expect HP gain with another non-OEM throttle body, any sugestions what i should get?
Thanks
Old Jan 13, 2007 | 10:38 AM
93supercoupe's Avatar
Default Re: H22 throttle body (Hondaen)
a bigger TB will give u some pwer, and they shouldnt stick no matter what.
Old Jan 13, 2007 | 11:16 AM
prelittlelude's Avatar
THe prelude throttle body has a fast idle thermo valve that connects to the bottom. coolant does run thru it but it can be eliminated. If you have a EMS you can tune you fast idle and everything down perfectly. I have blocked off my fast idle thermo valve and disconnected coolant flow from the IAC and FITV. I have never had freezing problems and i live in new england
Old Jan 13, 2007 | 07:00 PM
Hondaen's Avatar
Ok..
I will buy a BDL throttle body from Laskey and let the throttle body coolant go thru my water cooled turbo instead.
Thanks
Lith ium
Mar 7, 2017 09:58 AM
hkrichard
Apr 27, 2008 06:03 PM
Hondaen
Jan 14, 2007 09:47 AM
99ctr
Oct 5, 2005 12:23 PM
