converting my auto p28 to manual...
alright im ganna remove the rp17 and rp18. but then it says to repplace replace RP18 with a jumper wire.....im not sure what the jumper thing means? just run a wire across to connect them......right?
Re: converting my auto p28 to manual... (al3e)
nice truespin topsoul.
for the jumper you can use a small single wire and solder in between
the circuits.
basically whatever chip or diode you remove, you have to put a single
wire in its place.
the circuits.
wire in its place.
Re: converting my auto p28 to manual... (djhatch)
make sure you don't touch the board with the iron though because it will go to ****. I did mine it worked fine, then my friend did his and he burned it.
Make sure you got a good powerfull solder.
Copper wire is good for jumperwire because you can shape it into the form you want.
twotonecivic
05-04-2010 07:04 PM
94hondacivicvtec
05-08-2007 02:50 PM
