computer problem
Old Dec 28, 2004 | 06:33 PM
hatchpat's Avatar
Default computer problem
I have a 1998 Civic H/b, I put a 2000 Civic EX engine in and kept the DX wiring harness. I just picked up a 2000 Civic EX computer and a harness to change OBDIIA to OBDIIB and to use the EXs full potential (along with V-Tech).
I plugged the new computer and harness in and it is doing something weird.
At idle, it pulses from 1500 to 1600 Rpms, and when I give it gas, it only goes to 5000 Rpms.
Does anyone have a solution to my problem?
Please?
pattummillo@hotmail.com
thankx
Old Dec 28, 2004 | 06:37 PM
BatuKing's Avatar
Default Re: computer problem (hatchpat)
do you have any codes?:
Old Dec 28, 2004 | 06:49 PM
hatchpat's Avatar
Default Re: computer problem (BatuKing)
I haven't had the chance to check that yet, but I will.
Old Dec 28, 2004 | 08:17 PM
eK9aT10pSi's Avatar
plug in the map sensor plug or iavc connection in the back of the IM?
Old Dec 29, 2004 | 12:45 PM
hatchpat's Avatar
Default Re: computer problem (eK9aT10pSi)
i'll give it a try,
wish me luck
thanks
Old Dec 29, 2004 | 01:56 PM
99hatch's Avatar
you are in limp mode. if you just got a conversion harness then i dont think that means vtec , not vtech, is wired up and your knock sensor isnt wired up, so hard wire those into the p2p and you will be all set. also you have to wired up components from your intake manifold
Old Jan 1, 2005 | 01:13 PM
hatchpat's Avatar
Default Re: computer problem (99hatch)
this is true, I do not have v-tech right now.
Where is the knock sensor?
what do you mean,
"also you have to wired up components from your intake manifold"
Old Jan 1, 2005 | 07:10 PM
civic-4-ges's Avatar
You need to search for mini-me wiring quickly!!!
I also added to this same post, but in the Tech forum. Check it out for IACV issue
Old Jan 2, 2005 | 07:25 PM
hatchpat's Avatar
Default Re: computer problem (civic-4-ges)
where would I find the mini-me wiring ?
Any help would help.
Old Jan 8, 2005 | 03:36 PM
hatchpat's Avatar
well, I haven't had the time to do anything yet, the snow came and motivation left.
so I am still waiting, I think I will have it under control, but if I don't, I'll come back here to seek more knowledge.
thanks for all your help.
Joacnel
Aug 25, 2012 03:53 AM
NCSHERO
Aug 24, 2012 10:58 AM
InFaMouS_K
Dec 15, 2009 04:20 AM
hatchpat
Jan 8, 2005 03:39 PM
All Day
Jul 19, 2004 05:26 PM
