coilver adjustments
coilover adjustment
do you guys go by the gap between the wheel and the top of the well, or do you go with the same height of the threads???
[Modified by ep3, 9:12 PM 11/24/2002]
Re: coilover adjustment (gambit33)
thanx!! i did that too but i was wondering if i did it wrong because of the difference in the threads. does the difference in threads matter?
Re: coilover adjustment (E Prep)
The right way to do it is on corner scales.
The whole reason adjustable coil-overs exist.
Re: coilover adjustment (PatrickGSR94)
You should also be sitting in the driver's seat when you do the corner weights. Have a friend weigh/adjust them while you do this.
You want to have each corner as close as possible in weight.
Re: coilover adjustment (Peagreenhatch)
so the thread difference doesn't really matter?? on my front left, i turned it 16 times while on the front right i didn't turn it at all and they were even. is this ok or is left too high??
Re: coilover adjustment (ep3)
okay setting your car up on scales if just to corner balance the car for racing. The chances are he just wants the car to sit level for daily driving so there is no need to put the car on scales. The thread count really dont matter, and an easy way to tell if your car sits level is to look at the sideskirts to see if they are level.
