Codes p0135 and p0141
I just bought a 96 honda civic 2 door. D16y7. I have both the up and down stream o2 heater circuit codes. Both sencers are new and fuse 15 is ok. Any other ideas. I only have 5 more days to get inspection lol
Re: Codes p0135 and p0141
May or may not solve the issue but worth a try:
Disconnect both sensors and clean internal connections with electronic cleaner/lube spray from radio shack (or cheaper options on line)... then reset ECU by disconnecting negative terminal and turning on light/brights/ and step on brake pedal a few times to drain residual. Reconnect battery and with all electronics (radio, lights, A/C, etc.) turned off... start engine and let idle for few minutes. Hopefully codes will disappear and stay gone (not just temporarily).
I know its sounds odd as this is a problem with a lot of hondas. (Short circuit caused by intake manifold bracket) causing fuse 15 to blow. Theres a buliten for it from honda. But my is NOT blown. It seems to be acting just like that issue but i dont see the short and my fuse is not poping.
RedneckRicer
20
04-09-2014 08:19 PM
NSU.FL
01-14-2009 04:23 AM
