How to fix Code 91?
Old Nov 1, 2007 | 07:35 PM
mugenboi's Avatar
Default How to fix Code 91?
My 97 GSR throws a code 91. According to the ecu codes guide its for the Fuel Tank Pressure Circuit.
Can anyone give me some input on how to fix this.
Old Nov 1, 2007 | 08:16 PM
mugenboi's Avatar
i've already made sure that its not from a loose gas cap or fault cap.
Old Nov 2, 2007 | 05:12 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (mugenboi)
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenboi &raquo;</TD></TR><TR><TD CLASS="quote">My 97 GSR throws a code 91. According to the ecu codes guide its for the Fuel Tank Pressure Circuit.
how did you pull the code? i would repull the code using a scan tool which will yield a code starting with the letter "P" i.e. P0420
circuit = electrical, so vaccuum based things like your gas cap won't do a damn thing
and don't forget, since your car is obd2 the code has to be manually erased from the ecu, just changing something or turning the car off won't make it go away, it stores in the computer
FuNkDrSpOt
Mar 24, 2007 01:22 AM
ek_b16
12
Jan 30, 2005 08:01 PM
B16OnTop
Sep 1, 2003 08:59 PM
AamirCWITR
Jun 25, 2003 04:10 PM
