Clutch question (which to choose)
which should i choose for a standard d15 with just air intake and muffler changed:
1) F1 Racing Stage 1 clutch kit + Aluminum 7lbs Fidanza Flywheel
or
2) Exedy OEM Clutch kit + Aluminum 7lbs Fidanza flywheel?
thanks
or
thanks
Re: Clutch question (which to choose)
I think you will be unhappy with a flywheel that is that light. Anything under 10lbs is really a race only setup. i have an ACT streetlite flywheel (11.8 lbs) and even that is a bit difficult at times...
With something as light as 7lbs you are going to probably stall the car a lot and trying to keep the car in the fat part of the powerband will be hard because the revs will drop so fast...
you mean that it is better to keep a stock flywheel or at least a flywheel more than 10 lbs? and which clutch should i use an F1 racing clutch stage 1 or Exedy oem ? thanks
But yeah I meant get one that weighs more than 10lbs for a daily driven car.
Man U FTW
Get the Exedy. I ran a Stage 2 cerametallic on my stock block turbo GSR and i loved that clutch. After that i was sold on Exedy products. Also, i would go with a fly in the 11lb range...however with the longer stroke of the D series, it's almost better to give up a few revs and have the added kinetic energy of the heavier flywheel.
I am going to an F1 stage 1 clutch and an Exedy HF501 flywheel (10.9lbs). will it be too much for a stock d15b? thanks
Sounds good.. Just remember a staged (1, 2, 3 etc) is designed to grip, while an OEM clutch is meant for "economy" use and will last longer. Just my 0.02 cents, but either one will be fine.
318 Curves, 11 miles
Get the OEM exedy unless you're planning to boost later. You don't need anything more.
I don't really see the problem with a light flywheel. I had a 7.5# aluminum Fidanza on my y8 for like 3 years, and it wasn't hard to drive all - I taught my wife to drive manual on it, and she didn't even have a problem driving it. I think they do cause clutches to go bad a little quicker because you have a tendency to rev it more and slip the clutch more.
They do IMO make it a little more fun to drive, and seem to make it pull a bit harder because of the lower rotational mass on the crank.
ShinotakuX
10
09-15-2008 09:09 PM
tweekerz
07-28-2006 07:43 PM
