Tach issue for my 96 Civic with 00 GSR swap
Old 05-30-2011, 08:58 AM
sanjiyan69's Avatar
Default Tach issue for my 96 Civic with 00 GSR swap
I have a 96 EK DX that has no tach. So I swapped it for an EX cluster with tach. I tried two known working EX clusters and the tach still doesn't work. I then looked the blue wire that is C8 of the 13 pin plug.
link for picture
C8 for the tach is connected to the plug. So now I'm a bit lost. Is there anyway I can test for:
1. signal from the wire to the cluster.
2. tach DOES indeed work without putting in another EK.
Thanks!
Old 05-30-2011, 09:05 AM
Former User's Avatar
Default Re: Tach issue for my EK.....
If you have a scan tool that reads live data, you could check whether the ECU is getting the tach signal. Did you check the C8 pin in the cluster connector? Make sure the blue tach wire is attached to the ICM. Then check for end-to-end continuity of the blue wire from the ICM to the cluster. If that's fine, the ICM may be bad.
Old 05-30-2011, 09:30 AM
sanjiyan69's Avatar
I do not have a scan tool unfortunately. What is ICM? sorry I don't know a lot of the terms.
Old 05-30-2011, 09:31 AM
The tach receives its signal from the ignition control module (ICM) inside the distributor.
Old 05-30-2011, 09:36 AM
xOtakuBuster's Avatar
Ignition Control Module
Old 05-30-2011, 09:37 AM
sanjiyan69's Avatar
okay I've replaced that before in my other car. I will check that. Is there certain voltage I should be looking for?
Old 05-30-2011, 09:38 AM
Read post #2 carefully.
Old 05-30-2011, 09:41 AM
sanjiyan69's Avatar
will check if it's attached to ICM first.
Old 05-30-2011, 09:44 AM
sanjiyan69's Avatar
and of course I'm being an idiot. I forgot to mention that I have a GSR swap in it out of a 2000 teg. would that make a difference?
Old 05-30-2011, 09:46 AM
That could, I know when a buddy of mine threw a EX cluster in his DX it worked fine.
So the swap might be the problem
Old 05-30-2011, 09:47 AM
Hmmm...99-00 Civics get their tach signal from the ECU rather than from the ICM. If the 00 GSR is the same, then your distributor may not have a blue wire. Check that first.
I also updated your thread title.
Old 05-30-2011, 10:29 AM
sanjiyan69's Avatar
Default Re: Tach issue for my 96 Civic with 00 GSR swap
I will thanks. it is also run by a chipped p28 with a obd2a jumper harness. Checking it now.
Old 05-30-2011, 12:36 PM
sanjiyan69's Avatar
There is a solid blue wire connected to the ICM.... see pic
oh boy.
Can ICM be bad even though I was able to drive it??
Old 05-30-2011, 01:36 PM
Did you check the C8 pin in the cluster connector? Then check for end-to-end continuity of the blue wire from the ICM to the cluster. If that's fine, the ICM may be bad.
Old 05-30-2011, 02:54 PM
Technical Hero
HondaPartsHero's Avatar
How many wires do you have coming out of the B18 distributor? It may not be wired for the tach
http://www.hondata.com/forum/viewtop...10010&start=30
http://www.team-integra.net/forum/11...-ecu-swap.html
Old 05-30-2011, 04:19 PM
sanjiyan69's Avatar
My multimeter is MIA at this moment. Gonna have to borrow one from a buddy. Thank you all for your help! will update when I found out what happened...
Old 06-29-2011, 06:52 PM
Snou52's Avatar
any updates on this? i'm having the same issue after swapping out my timing belt...disconnected the distributor connector and plugged it back in and now my tach stopped working. i think it may be a loose connection somewhere, does anyone know which blue wire out of the distributor is the actual tach wire, my distributor has 2-3 different blue wires?
i have a gsr swap in my 97 hatch as well.
soccermike
08-21-2010 02:06 PM
GriFFIthS
Honda Civic (2001 - 2005)
07-07-2010 07:00 AM
hondanube2010
06-30-2010 05:10 PM
Wazup
12-04-2007 05:09 PM
99sibluehatchwitb16
01-26-2006 12:47 AM
Quick Reply: Tach issue for my 96 Civic with 00 GSR swap
