cluster problem
cluster problem
ok for 3 days now my cluster has been acting up..my speedo works fine but my gas and engine temp are off..what could this be..i put in 10 bucks worth of gas wich usually gives me half a tank when i put it in the meter only rose a little bit above the empty line..wat can this be?
Re: cluster problem (305accord)
The place to start is just to pull it out and make sure all your wires are connected tightly. Otherwise, swapping in a new cluster is easy.
from my experience with cluster when i first bought my ek , my cluster was like that too along with the temp, i went to the junk yard and bought me a used cluster and swap out the whole piece (the facew/the motor in the back off the cluster) put it onto my old cluster and now it work fine.
Re: cluster problem (Donhonda84)
ok but i dont want to buy a new cluster and that not b the problem..is there anything else that mite be casuing the problem
